Need help?cnc lathe unusual vibration
Results 1 to 4 of 4
Thread: Need help?cnc lathe unusual vibration
    Member BernhardBottigheimer's Avatar
    Jan 2024
    Question Need help?cnc lathe unusual vibration
    Hello?
    Recently, my CNC lathe has been vibrating excessively and making noise. Could this be related to the hot weather? Any advice?
    Member maximebonnin's Avatar
    Jan 2024
    Default Re: Need help?cnc lathe unusual vibration
    What kind of noise is it? Do you have video of it?
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Quote Originally Posted by BernhardBottigheimer View Post
    Hello?
    A bit more info please...
    - is it while taking a cut, drilling, parting off ?
    - is it when moving axes, with spindle off ?
    - is it when NOT moving axes, but with spindle running ?
    - does it vibrate when moved by hand (when powered down) ?
    - where do you think the vibration comes from ?
    Member cncmakers001's Avatar
    Jul 2011
    China
    Hello?
    Could be the AC Servo Motor problem, you can check X and Z axis motor.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
