Newbie Q: Why do CNC machines have such big motors?
Results 1 to 8 of 8
Thread: Newbie Q: Why do CNC machines have such big motors?
    Member ballsystemlord's Avatar
    Sep 2021
    Georgia
    Default Newbie Q: Why do CNC machines have such big motors?
    So I have been looking at CNC machines, such as this one https://www.tramarindustries.com/lis...#machine-specs and I noticed that most CNC machines have big motors on them. The one linked has a 25HP motor. I expected that to turn a shaft to cut metal it would be more like a 10HP motor.
    Obviously, CNC machines will use the 25HP of their motors' if they have it. But I'm rather lost as to what exactly they'll use all that HP for.
    Thanks!
    Jan 2013
    england
    Quote Originally Posted by ballsystemlord View Post
    Thanks!
    In simple terms, they don't.
    Those with "big" spindle motors tend to run at lower speeds for bigger components so able to have enough torque to cut metal.
    For example, the 8000rpm speed quoted is quite high, but maybe due to gear ranges. So probably has a lot of grunt at lower spindle speeds.
    Dec 2013
    Default Re: Newbie Q: Why do CNC machines have such big motors?
    This is why
    Jim Dawson
    Sandy, Oregon, USA
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    it is interesting how servtech talked about low rpm high torque application, and jim showed high rpm low torque
    and the average user is in between / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jan 2013
    england
    Quote Originally Posted by deadlykitten View Post
    Indeed.
    But for example a 5 litre diesel engine in low gear has a lot of torque. That's why you change down to climb a hill or a tractor to plough a field. It's all about getting the motor into its optimum power band. Same applies to cutting metal.
    Dec 2003
    DC - BLDC motors exhibit the highest continuous torque at zero RPM, consult the manuf. Torque/RPM charts.
    Jun 2018
    on my feet
    I'd say that daewoo in the link is more designed for lower speed hogging based on it's specs . Most big insert tools for steel jobs require a lot of torque . A 4" porcupine for example needs a lot of power behind it to use the tool to it's fullest potential . Hogging needs a big spindle motor as do high speed high feed machines , their requirements are just different
  8. #8
    Sep 2021
    Georgia
    Thanks everyone. That answers my question.
