Hello
Some time ago my matsura MC510VG J300 control was damaged. All parameters have been lost.
I got the parameters from matsura. But after entering all of them, my nikken Cnc 170 divider does not work.
It was controlled by the M-code M11. The rotation by a given value is controlled from a separate panel.
Does anyone on the forum knows what parameters need to be changed so that the machine can see the dividing line and be able to control it.
And on a different note, does anyone know how to change the orientation of the spindle after replacing the plate springs in the spindle?
Parameter 1414 tried and value 4 and value 1000 but after entering M19 it is set the same
Thank you for any help
I also have a MC510VG J300. I am wondering if you would mind sharing your parameter list. After also having some control issues I have some issues regarding some missing parameters. Id be happy to share mine if it helps you out at all in the future. Thanks
