I'm encountering a strange situation regarding an Indramat Graziano GT300, the power supply of the PC was faulty and after it was repaired the PC after booting is giving the following error: Can't connect to CNC.
The PC unit is named BTV30 and is having two logic boards each with a 8 digit display. On the first the digits are shiwing a "b" letter and the digit of the second board is showing an "8". As I read the b means board ready and the 8 means the self test is not done.
From the second logic board are going two fiber optic cables to the drive units.
The COM1 cable from the BTV30 unit toward the BTV15 unit we found at a speed of 1200 baud. At this time we are not sure if any other data could be alterared.
Is there anyone who is having some experience on Indramat?
