Maybe the lubricant pump or the lubricant pressure sensor?
Hello Community. We have A Femco HL-25 from 2002. When you turn the main switch located on the back, everything seems norma, then you push the ON/OFF button and the READY button starts flashing like normal. But the message "insufficient Lubricant" pops up on the screen, and when we push the REDY button nothing happens, nit keeps flashing and nothing else happens. We already replaced the I/O PCB3 board, the oiler, the 24Vdc power supply and we still have the same problem. all fuses, contractors and breakers have been checked. Any help or ideas would be highly appreciated.
Thanks.
- Need Help!- FEMCO HL 25
- Need Help!- Femco Durga 25E 1998 year/ Aligning Turrets Procedures
- Need Help!- femco hl-55
- Puma 2500SY YEAR 2002
- FEMCO
Jim Dawson
Sandy, Oregon, USA
Thanks, I have the pressure switch sensor with a jump between 109 and 190. so I'm bypassing the pressure or level sensor.
