- Need Help!- FICEP TIPO D8
FICEP TIPO D8
Hello,
I have a issue with shear rotation, it's literally not moving.
When I change the angle on the machine screen the machine believes it is moving
When I manually push the shear the correct angle is fed back to the machine correctly
I have checked the motor electrically and every is good.
I have changed the cable from the motor
I have tried a replacement card in the electrical cupboard
Any suggestions of what to try next would be apparated
- You may not post replies
- You may not edit your posts
Forum Rules
