Need Help! Matsuura MC-760V Spindle issue
Results 1 to 6 of 6
Thread: Matsuura MC-760V Spindle issue
    Sep 2016
    Default Matsuura MC-760V Spindle issue
    We have an old Matsuura MC-760V2 mill with a Yasnac MX2 control.
    Lately, at spindle stop (M05) or orient (M19) command usually for tool change, the spindle physically stops or orients, but the spindle run indicating light stays on, and the machine pauses sometimes from a few seconds to multiple minutes without alarm or error before continuing with the operation.
    Normally the spindle run indicator light turns off when the spindle stops. Even now it eventually turns off after the pause.
    I assume, that there is a switch or sensor that is malfunctioning.
    Would anyone be able to help us to troubleshoot, and locate the faulty item?
    Your help would be greatly appreciated.
    Oct 2008
    Default Re: Matsuura MC-760V Spindle issue
    And you posted in the Fadal forum???
    Sep 2016
    I'm sorry. I did not realize that it was in the Fadal forum. Is there a way to remove it?>
    Oct 2008
    I don't think it bothers anyone. I only mentioned it because I figured you did it by mistake and most likely wouldn't get many responses.
    Dec 2013
    We don't have a Matsuura forum, so maybe this is as good as any.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    Incidentally i just moved it here.
