Any Trapezoidal tooth Timing Belts will all be noisy
Here is what all the Timing Belts are and which is best, GT2 or GT3 is improved version of the GT2, is by far the best Timing Belts on the market, if you are not doing rigid tapping then you should be using a Poly-V-Belt around 10 or 12 groove J type would be best, a poly-V-Belt can be used for rigid tapping, if it is correctly tensioned and not over loaded, a Poly-V Belt is almost silent.
