We have a Taiwan Takisawa 110 lathe with system fanuc series 21i-TA
the issue with it now is that when we changed the batteries in the machine, the machine zero point has been moved
how do we change the machine zero point manually?
all the machine settings looks fine, exept the x-axis is wrong with about 30mm on the diameter. We dont know which parameter you can change that on. so we are wondering if anyone know which one?
