Should I shim those bearings?
Results 1 to 4 of 4
Thread: Should I shim those bearings?
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Should I shim those bearings?
    I'm converting my BF20L mill to CNC. In the axes ball screw end support I used 2 deep groove ball bearings. In the Y axis there was some play so I shimmed the bearings using 0.1mm. much better but there is still some play. Is this amount of a play acceptable or do I need to add another shim?
    Sent from my MI 5s Plus using Tapatalk
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Jan 2018
    United Kingdom
    Default Re: Should I shim those bearings?
    Quote Originally Posted by Azalin View Post
    Why have you not use angular contact?.
    Do it once, do it right.
    You shouldn't need to shim anything if you have the ballscrew, bearings, nut set up right.
    How have you put the bearings in?. Do you have a stopper ridge central inside the mount and then a bearing each side?.
    This will allow the bearings to press back to back as the nut is tightened thus eliminating play.
    If it is set up like this above and the nut is correct, then that's your backlash I'm afraid.
    Member arizonavideo's Avatar
    May 2008
    Buy some AC bearing they are about $7 each. You might need more shims. Set them tight so you can not feel any play in the bearings and it will only spin 2 turns or so by hand if you remove the bearing mount in hand..
    . You might have some play in the ball nut but you need the bearing tight first.
    youtube videos of the G0704 under the name arizonavideo99
    Mar 2014
    Turkey
    Quote Originally Posted by arizonavideo View Post
    Yes, thanks.
    Suat
