Sanity check: CNC mill with DRO.
Results 1 to 3 of 3
Thread: Sanity check: CNC mill with DRO.
    Default Sanity check: CNC mill with DRO.
    Hi all:
    About a year ago I purchased a PM-728-VT Ultra precision mill. I also installed a DRO
    so I could do some work while I collected all the CNC items for it.
    I installed a Centroid Acorn system with Clearpath servos
    and have it running. I highly recommend this system.
    My question is, should I keep the DRO? it's allways
    1 or 2 thou off from the CNC display. But it does give me
    an idea if everything is working ok. It is a cheap Chinese DRO
    I may be able to calibrate to the CNC. I may give it a try.
    Anyone have set up like this??
    Any advice appreciated.
    RonL
    Jan 2008
    Default Re: Sanity check: CNC mill with DRO.
    What do you mean by 1 - 2 thou off?
    Difference in travel measured? Over what distance?
    You won't do any harm by having a DRO sitting there. Not sure it does you much good though.
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
    Sorry, 1 to 2 thou off over 10"
