Normally computing over a longer distance is better. I would set to 10.144, then spot 2 divots at the maximum distance your machine will allow and measure with a tape measure. It is possible that what you are seeing is ball screw wear. Or just a bit of error in the original calculation.
I assume that you have a 2:1 belt reduction on the drive, and a 5mm lead ball screw.
