I got this machine and as the title says, I need a little help. I have got two programs to successfully run using "fixture offsets". However, I cannot get any other programs to run after the first two - even if it is an identical program. When I check the "status" it says "running, awaiting M-reset". It can be a simple program that only turns on the spindle and it won't run. The previous programs still run fine. What am I doing wrong?
