They may well be transfer punches and it looks like they have seen some use.The idea is that you lay a pattern on top of the job and after aligning or scribing the edges you slot the appropriate sized transfer punch in the holes in the pattern and tap it with a hammer to give the centre of the hole in the part.The conical tip should leave an indentation for the punch or centre drill to engage with.
