making bolts unconventionally...
Results 1 to 5 of 5
Thread: making bolts unconventionally...
    Jul 2003
    Holmen, WI
    Default making bolts unconventionally...
    A bit of math and linuxcnc... Converted little emco compact 5 cnc
    Jul 2003
    Holmen, WI
    Default Re: making bolts unconventionally...
    Member CitizenOfDreams's Avatar
    Nov 2012
    Pretty cool, but Harley-Davidson might sue you for that sound starting at 3:10.
    Aug 2005
    neat. whats your g code look like?
    Jul 2003
    Holmen, WI
    some more cutting with slow mo...
    The gcode currently sends the HAL layer the settings it needs. I hope to do a remap of gcode soon.
    (polygon radius)
    m68e0q.30625
    (number of sides)
    m68e1q6
    (Cutter diameter - probably get from the tool table in the future)
    m68e2q.375
    (rotate poly 0deg)
    m68e3q0
    (enable polygon component)
    m64p0
    (disable polygon component)
    m65p0
