- MAHO 600E W/N - Philips 532 - problem !!!
Dear colleges,
We have a cnc machine MAHO 600 E W/N /four axes/ with CNC controller - Philips 532.
For a long time we are trying to start that machine and different problem appears at every step.
!!!The main is that the INDRAMAT servodrive can NOT be enabled and NO axes move can be done!!!
At the moment, our last suggestion is that something is not correct with the "IPLC" data /please, check attached files/ - We do not have such data!!!
If possible, someone that have such machine configuration to check, give some suggestion, or attach his pictures of the mentioned "screens".
Every support will be highly appreciated.
Thanks and best regards
Re: MAHO 600E W/N - Philips 532 - problem !!!
[QUOTE = simbad; 2385519] Dragi fakulteti,
imamo cnc stroj MAHO 600 EW / N / ?etiri osi / s CNC upravlja?em - Philips 532.
Ve? dugo pokušavamo pokrenuti taj stroj i na svakom se koraku pojavljuje druga?iji problem.
!!! Glavno je da se INDRAMAT servodrive NE može omogu?iti i NE MOŽE se pomicati osovina !!!
Trenutno je naš posljednji prijedlog da nešto nije u redu s podacima "IPLC" / provjerite priložene datoteke / - Mi takve podatke nemamo !!!
Ako je mogu?e, netko tko ima takvu konfiguraciju stroja provjeriti, dati neki prijedlog ili priložiti svoje slike spomenutih "ekrana".
Svaka podrška bit ?e visoko cijenjena.
Hvala i lijep pozdrav [/ CITAT]
switch S2 on (1)
N900 C1 --------- 1-RS232 ; 2-RS422 ; 0 no comunikacion
N901 C19200 --------- BAUD
N903 C1 --------- stop bit 1 ili 2
N904 C30 --------- time u milisec
N905 C1 --------- data op. 0-ASCII ; 1-ISO ; 2-EIA
N906 C1 --------- prepoznavanje DATA 1-automatski ; 0-ne
N907 C2 --------- protokol 0-RTS/CTS OFF ; 1-RTS/CTS ON ; 2-XON/XOFF
N908 C1 --------- DTR 0-NO ; 1-YES
Dear Kojaze,
Many thanks for you detailed answer and I do apologize for my very late one.
Due to different reasons, I'm still on the same phase with the machine.
I've uploaded your constants but the situation is the same.
Also, there appeared a message that the "IPLC program" is missing!!!
Shall you be kind to send me a picture of your "blue screen"?
Many thanks and best regards
- You may not post replies
- You may not edit your posts
Forum Rules
