Hi JR - Infusion is a process where you have a "closed" mould or a vacuum bagged mould. You stack dry cloth, timber, sand, sawdust whatever you like into the mould then evacuate the volume. You then use the vacuum to draw in resin and fill the void. This does a few things 1) It fills the void entirely if done correctly 2) the vacuum removes water vapour from the matrix which is a big inhibitor to epoxy sticking to the matrix and water vapour or dew is on everything generally. You can see the vapour coming our of the pump... It also applies 1 atm pressure to the pack 10tonne / sm so you consolidate packs very well. Do searches on composite infusion. For epoxy granite you don't need a super dooper vac pump either as its quite porous compared to doing a CF laminate for instance.
Please note PVA used as a release is not the carpenters glue!! White glue should be called PVAc if you look it up. Glue is poly vinyl acetate whereas release is Poly vinyl alcohol... it is impermeable to gases so various outgassing and desorbtion and mould stick ups don't occur.
Steel shot is used in grit blasting and is available in various sizes and types. Being steel its modulus is 200GPa which is 3x more then sand so the resulting polymer concrete or epoxy granite is 3x stiff. Its also heavy so you get a good mass addition if you want. The photo of the filled mould shows the filling marks over a period of about 15mins. I have done a 50ft boat some years ago that used 400kg of resin over a 1 hr period to fill. So size does not matter. You will need a very thin infusion epoxy, a laminating epoxy will only travel a short distance.
You could use sand and other ceramics but I want to be able to post machine parts in my router so I need a material that machines easily. Do a search for Tetrium-S this is something I make at the moment or Tetrium-A.
Infusion has many names but it is now the preferred process in aerospace. Its called an "out of autoclave process" It allows huge structures to be made without an autoclave which saves a huge amount of time and $$$. Cheers Peter
https://www.eit.edu.au/cms/news/indu...ineering-award
