Maho MH600E Error 0 23, I 05
Results 1 to 8 of 8
Thread: Maho MH600E Error 0 23, I 05
    Member minisoren's Avatar
    Apr 2020
    Default Maho MH600E Error 0 23, I 05
    Anyone know how to solve error code ERR 0 23, I 05
    Philips 432
    Sep 2008
    Romania
    Default Re: Maho MH600E Error 0 23, I 05
    I05 is normal until you power up the hydraulics , O 23 is an operator error that appears when you type something wrong at the controller. I am amazed that no one sims to replay anymore on this forum.
    Apr 2020
    Hi Thanks for the replay
    I manages to get rid of the O 23 error, the backup battery were dead so I had to enter all the constants again.
    I still have the I05 error and the hydraulic will not start only if I keep my finger on the button.
    I have tried to activate the switch for the axis end stop to see if switches for the axis is jammed, but I still have the error.
    Sorry for my late replay I am new in the forum.
    I have open a new thread with a picture I didn't know how to add a picture in this one.
    Attached Thumbnails Attached Thumbnails Maho MH600E Error 0 23, I 05-i05-error-jpg
    Sep 2008
    Romania
    If the limit switches are clear than you should know that there is a technique for powering one the hydraulics. Firs if the machine has sat over night , press the hydraulic switch for a couple of seconds to build up pressure. Than the procedure it self is to keep the hydraulic button pressed for a second ore two with one hand than immediately after depressing it press the CLEAR button. Normally the OPENLOOP will be gone and the machine will work.
    Apr 2020
    I tried what you recommended but hydraulic stop when I release the button, and I have the error that is showed on the picture.
    When I tri to start, all the safety gates are closed and no emergency buttons are activated.
    Sep 2008
    Romania
    Quote Originally Posted by minisoren View Post
    Are your constants ok? Is the table all the way down?
  7. #7
    Apr 2020
    Constants seems ok, i am able to start and run all 3 axis to reference point.
    Next step spindel RPM and tool changes check:
    If i try to start spindel i get alarm E93. i use S600M3.
    If i try to changes the tool, the tool magazine just keep spinding ( tool magazin is emty) but it should do the opreation anyway? T6M6
    Attached Thumbnails Attached Thumbnails Maho MH600E Error 0 23, I 05-e93-jpg
  8. #8
    Sep 2008
    Romania
    The Maho mh 600 e has a gearbox for speeds. So you ca only imput fix speeds like S 500 , S630 .
