- ProtoTrak MX2 X axis quit
I have a Lagun FTV 2s w/prototrak MX2 and the X axis died..
DRO is working, switched the Y axis cabling over and it operates, will jog but fault out because DRO is not seeing movement....
Error displayed is fault X
Everything else seems to be working but can find no detail on the electrical..
Am suspecting the output board on the main unit or the link from the console to the control box (data cable shows continuity on all pins)
Any other hints? a link to a schmatic of the control electrics system would be awesome..
Thanks..
- You may not post replies
- You may not edit your posts
Forum Rules
