There is a cover on top of unit about 65 dia take it off to see solenoid I can't remember exactly what relay I think it is top row 2nd and 3rd from right I do not have drawings in front of me
ok but one more thing i want to tell you before replace the relay..that turret is working in both directions for example when i call tool #1 the turret rotate ccw direction stop at position 1 but not locked so i have to press reset button and then call tool#8 the turret rotate cw direction and stop at position 8 still not locked so i again press the reset button .........its look that turret rotate both ccw and cw direction.......NOW please tell me Sir..still we need to replace relay 5 and 6????
Along the top from 4 to 8 are the relays for your turret check they are working. 6 is your shot bolt had this last week changed 5 and 6 started working however you have never said it works in reverse before
Good luck
.as I said ages ago have you checked you are getting 24v to the turret
ok sir as per your instruction i have check 24v DC and it is coming at turret .
about relay ..i check relay form 4 to 8 .......and as per my understanding relay work well...
how i checked now i am telling you .
1st i call tool#1 the turret rotate CCW and stop the position1 (but not locked)
now i remove relay #4 and call tool#2 but no response in fact in jog mode manual tool change is not activating.
then i reconnect relay#4 and do same process like above mention and the turret work ..i apply this procedure on all relay #4 to 8.
except relay # 6 all relay showing difference when connected and not connected...relay# 6 show no change either connected or not connected..\ ...........now what to do
Check turret motor proximity sensor gap/clearance is correct,then reset turret timing as mbservice advised earlier.this sensor could be faulty/breaking down.
Jono1961 thanks for join our conversation... r u talking about 6# sensor please check jpeg...highlighted with black circle?? i already maintain the gap between sensor and metal ring as per manual instruction..its 0.8mm to 1mm gap..
2nd thing i dont know how to reset the turret timing can you guide me please
ok jono 1961 so your advise that i change locking control switch and reset the turret timing..but how to reset the turret timing can you guide me please.
