Nakamura AS200 Need Help!
Results 1 to 1 of 1
Thread: Nakamura AS200 Need Help!
    Member tommyboycsc's Avatar
    Jan 2020
    Default Nakamura AS200 Need Help!
    I'm trying to set up a used Nakamura-Tome AS200 lathe we got at work, and I have a couple questions about it if anyone can help.
    1. The enable switch is supposed to allow manual movement of the machine with the door open for 2 minutes after activation according to the manual, however it disables as soon as I release it, so I have no way of touching my tools to the part with a feeler to set my offsets. Has anyone else had this problem?
    2. I would like to graph the part I'm programming before running the program to ensure it won't crash, and that everything looks correct, however I can't figure out how to graph it without the machine actually moving into position. Is there a way to just have it draw the graphic without moving the axes?
    Thank you for any help you may be able to give.
    maryxeniia's Avatar
    Feb 2020
    Do not know how I can help you? I am ready to make any requests that you make! the impossible quiz
