- yasnac mx1 on matsuura mill couple parameter q's
Looking for parameter to change air during tool change being off
and
parameter to open up more memory
Prior to a recent upload thru rs232, causing machine to "lose its mind" We had to re-enter all the parameters. I was sure we had a copy of them, but couldnt locate, Got a copy or params from methods, which got us very close. Had to adjust 6036 for atc vs z limit.
What I have now, it machine thinks it only has ~8k bytes when previously it had ~26k, looking for what parameter to change to fix that.
Also
tool changer used to do a blast of air on tool removal, and another once it had cycled carosel to the next tool. Now its just blasting air while the carosel is cycling through tools. So a change from t1 to t10, is just constant air blowing.
Ideas? thanks!
Re: yasnac mx1 on matsuura mill couple parameter q's
It might be a little late by now but I think (I read some of your old posts) I may have the same machine so I can probably pull parameters for you (plus I have the original parameter lists). Like you, I've been looking to see how I can alter the machine (I'd like to have probing, 4th axis, spindle encoder so I can do G95). Maybe we can help each other!
Bob
- You may not post replies
- You may not edit your posts
Forum Rules
