MAZAK T32-2 Control panel suddenly died
Results 1 to 4 of 4
Thread: MAZAK T32-2 Control panel suddenly died
    Jan 2013
    Default MAZAK T32-2 Control panel suddenly died
    Hy did you solve the problem?
    I suddenly lost the power on the control panel, I checked the fuse on the power supply behind the control panel and the fuse was blown. I replaced the fuse but I am not getting any voltage on output pins.
    There is a 6 PIN output with wires.
    RED/WHITE/BLUE/RED/WHITE/not connected.
    The PSU should output +5V(3A)/+12(0.4A)/-12V(0.4A) but Im not sure which voltage goes on which pins.
    I was thinking to use PC PSU instead but I need to know which voltage goes on which pin.
    If anyone could help that would be awesome.
    Attached Thumbnails Attached Thumbnails MAZAK T32-2 Control panel suddenly died-20190904_132425-jpg   MAZAK T32-2 Control panel suddenly died-20190904_131603-jpg   MAZAK T32-2 Control panel suddenly died-20190904_122948-jpg
    Jan 2013
    Default Re: MAZAK T32-2 Control panel suddenly died
    If anyone can check with multimeter output voltages on the CNP82 connector that would be great.
    I tryed to trace the leads and came up with output but Im not sure if its right.
    MAZAK T32-2 Control panel suddenly died-20190904_190439-jpg
    Member Mecanix's Avatar
    Aug 2019
    Quote Originally Posted by mlinkadelsol View Post
    In a meantime drag your question over to Practical Machinist . com. Lots of folks there would still have the Maintenance Manual and could snap a few pics of those schematics for you.
    Jan 2013
    Quote Originally Posted by Mecanix View Post
    I did post on both forums.
    Thank you.
