A pencil grinder in the lathe toolpost and a CNC controlled lathe.
I'm looking to engrave a small logo 1" in size into mild/hot rolled steel. Doesn't have to be very deep. I've looked at lasers but I would need a fibre laser. A CNC mill might work but not sure. My budget is 1k so I know I'm limited. Any other ideas?
I have co2 Engraving you can use Cermark spray to engrave in black
You can buy these under 1k
Or
This
https://gtschmidt.com/pin-marking
Sent from my MHA-L29 using Tapatalk
Etching
Reverse logo stamp.
Yes stainless would work also
I suggest tool steel and heat treat then it should work
I can do it on hardened tool steel.
