- machining accuracy
machining accuracy
I would like to do some very fine engraving and be able to use a dia. 0.1 mm end mill for some of the details.
I own a Denford Triac.
1. If I fit a high speed spindle on the side would my cnc milling machine be capable of milling tiny features in steel.
2. What rpm would I require ?
- You may not post replies
- You may not edit your posts
Forum Rules
