New Machine Build Student organization looking to build CNC milling machine for school donation - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: Student organization looking to build CNC milling machine for school donation
  1. #41
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Student organization looking to build CNC milling machine for school donation
    Hi 308 - No release necessary. The parts will come apart when needed to. Release films may affect the curing of the adhesive. Only set the machine once it has bedded in and its joints are pulled down for the last time. Look up asperity. Cheers Peter S
  2. #42
    Thanks for the info!
  3. #43
    Jul 2018
    dum dum
    Hi 308 - Just another thought. Edge drilling and tapping holes can be a chore in this sort of machine & if you strip one it's a thread repair. Think about using nut pockets. As you will be profiling the parts you can easily machine a nut pocket. Then when you do the edge hole the jobs done. Figure out your spanner clearance or make a narrow spanner to minimise pocket size. Cheers Peter
    Attached Thumbnails Attached Thumbnails Student organization looking to build CNC milling machine for school donation-bolt-detail-1-jpg   Student organization looking to build CNC milling machine for school donation-bolt-detail-2-jpg
  4. #44
    Interesting idea! do you know how that affects rigidity if at all?
  5. #45
    Jul 2018
    dum dum
    The global stiffness will be the same. You have to do some analysis to figure it out exactly. Peter
  6. #46
    Jan 2008
    Quote Originally Posted by peteeng View Post
    Hi 308 - Just another thought. Edge drilling and tapping holes can be a core in this sort of machine & if you strip one its a thread repair. Think about using nut pockets. As you will be profiling the parts you can easily machine a nut pocket. Then when you do the edge hole the jobs done. Figure out your spanner clearance or make a narrow spanner to minimise pocket size. Cheers Peter
    Or just make the pocket a sliding fit for the nut so that the pocket is the spanner.
  7. #47
    Jul 2018
    dum dum
    Hi 308- Since I had the little bolt model I made for you I did a simulation on the connection. Simsolid shows one assembly slipping while the other does not. The solid side is at full pretension the slipping side is at 1/10th pretension. I suggest you talk to Altair and get a student copy of Simsolid. It's the best software for doing this sort of thing. Peter
    https://www.facebook.com/ScootCNC/vi...2627793608277/
    https://altairhyperworks.com/
  8. #48
    Quote Originally Posted by pippin88 View Post
    exactly what I was thinking!
    - - - Updated - - -
    thank you for the suggestions! I will look into it
  9. #49
    Jul 2018
    dum dum
    Hi 308 - Hows the project going? any updates? Peter
  10. #50
    Jul 2018
    dum dum
    Hi 308 - How is the project going? I found an article on the measured stiffness of a machining centre. It was 167N/um so its really stiff. And I added an analysis of a spindle as well. Cheers Peter S
    Attached Files Attached Files
