Need Help! How do I setup a cnc lathe?
Results 1 to 13 of 13
Thread: How do I setup a cnc lathe?
    Jul 2009
    Default How do I setup a cnc lathe?
    OK, finally got my little cnc lathe in-place up and running. But I'm having trouble getting my head around it doesn't have a machine home position, what is the right way to set a home X0Z0?
    Member ChrisW's Avatar
    May 2003
    Lake In The Hills
    Default Re: How do I setup a cnc lathe?
    What control?
    Sent from my MHA-L29 using Tapatalk
    Jul 2009
    It's a Washing W-31DT if that helps.
    Dec 2013
    You could set each tool Z zero to the chuck face, and each tool X zero to the spindle centerline. Then all you need to know is how far the work is sticking out from the chuck.
    Jim Dawson
    Sandy, Oregon, USA
    Member machinehop5's Avatar
    Aug 2009
    Any Photos of Control ...etc?
    May 2003
    Lake In The Hills
    If its so old you may need to do G50 X.... Z..... From part zero.
  7. #7
    Jul 2009
    How do I setup a cnc lathe?-image1-jpeg
    How do I setup a cnc lathe?-image2-jpeg
    ChrisW I don't have G50
    Jim I will try that and see how it goes.
  8. #8
    May 2003
    Lake In The Hills
    Any previous or sample programs
  9. #9
    May 2003
    Lake In The Hills
    User manuals?
  10. #10
    Jul 2009
    Yes there are a couple of test programs in the memory of the controller. Well the "user manual" I got has very little in it and I think it's written in "Chinglish" no help at all
  11. #11
    May 2003
    Lake In The Hills
    Take screen shoots and post here
    Try better resolution cant zoom on the picture you posted
  12. #12
    Jul 2009
    ChrisW, will get a better picture today and put it up, got stuck with work yesterday.
  13. #13
    Jul 2009
    Sorry it has taken me a bit to load the photo been stuck with work.
    How do I setup a cnc lathe?-img_3465-jpg
    How do I setup a cnc lathe?-img_3467-jpgHow do I setup a cnc lathe?-img_3468-jpg
    The last line of the program is missing the M30 the other 2 programs on the machine do have it on the last line.
