please, what is negative diff ( following error < 0 ) ? or what do you believe it is ? is it ok to have it ? does it has effects ? kindly
note : following error is defined as the difference between the command value output from the NC and the
output of the position encoder. A diff over alarm occurs if a following error exceeds a certain value
during rapid feed or cutting feed of an axis.
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
