I should mention that the lathe does power on... but the power feed button doesnt.
Lathe power up. Its a Grizzly G0750g 12x36 gunsmithing lathe. https://cdn0.grizzly.com/manuals/g0750g_m.pdf
I just figured out how to push that blue dial on the right in, give it a quarter turn and it locks in, but that red button wont stay in. No idea what to do.
Did you check the fuses?
Jim Dawson
Sandy, Oregon, USA
the fuses were fine. they would have lit up if they were bad.
figured out the problem. KA0 needed to be reset. I didnt even know you could do anything with these things. Called tech support and they talked me through the problems. The cover comes off, and I touched it slightly and it fell back into place like a GFI contact and it fired back up. I knew it was something simple. Hopefully if someone else has this problem after a crash, they find this thread.
