Tsudakoma rncm-251r rotary worth saving?
Results 1 to 4 of 4
Thread: Tsudakoma rncm-251r rotary worth saving?
    Apr 2015
    Default Tsudakoma rncm-251r rotary worth saving?
    I was given a tsudakoma rncm-251r rotary table not to long ago and am finally getting around to bothering with it. The drive motor is missing, as is the accompanying gear. I currently have a VH65 on my Fadal 3016 and would like to possibly have a dedicated truinnion table. I originally intended to rebuild the unit and adapt a glentex motor to the tsudakoma table. I was hoping to get some opinions on adapting a Fadal (Glentek) motor to the tsudakoma. Is it worth the time and effort? Is it even possible? The Tsudakoma unit looks to be in pretty good shape, it doesn't look like it has any damage, but I will not know until I tear into it. Any suggestions?
    Jun 2010
    Default Re: Tsudakoma rncm-251r rotary worth saving?
    Photos! Esp of the motor port.
    Cheers
    Roger
    Apr 2015
    Tsudakoma rncm-251r rotary worth saving?-img_0017-jpgTsudakoma rncm-251r rotary worth saving?-img_0016-jpgTsudakoma rncm-251r rotary worth saving?-img_0018-jpg
    It will definitely need a tear down and clean up if I go through with this.
    Attached Thumbnails Attached Thumbnails Tsudakoma rncm-251r rotary worth saving?-img_0017-jpg   Tsudakoma rncm-251r rotary worth saving?-img_0016-jpg   Tsudakoma rncm-251r rotary worth saving?-img_0018-jpg
    Jun 2010
    Good Lord - what a solid bit of steel.
    Nah, not worth saving - pass it on.
    You should be able to buy the pinion almost off the shelf. Maybe Tsudakoma might even sell one to you? RIGHT size! (Spare Parts Dept.)
    Cheers
    Roger
    PS: Australian humour ...
