hello
is the camera ( rigid ) inside a toolholder ? tool change sequence precision isn't enough, so you still need to fine tune ? how much do you fine tune ?At the end of each sequence, the operator must handwheel the camera for fine adjusting the position
can you share a list of Z coordinates for each run, like for an entire day, or 50 cycles ?
about less keystrokes, i can't help, because i don't have experience with heidenhain; i can do it on okuma ; kindly
ps : why are you using the camera ?
