Need Help! BT40 spindle year dowm
Results 1 to 1 of 1
Thread: BT40 spindle year dowm
    Sep 2017
    Default BT40 spindle year dowm
    Purchased this BT40 off eBay and somehow during transit it was saturated with moisture and arrived orange from rust. So in process of making this a usable spindle I would feel far more comfortable tearing it down, cleaning up, and reassembly. The bearing themselves feel ok when spinning though I know any moisture inside will eventually eat them up. A good cleaning, degrease, and regrease is in order. Issue I am having I want to remove the timing pulley and I believe the taper is threaded on however I’m hoping someone can clarify this for me and which direction so I don’t damage anything pulling it apart. It doesn’t have a slot or removal holes which further suggests it is threaded on. This is a custom build so I cannot offer up an application for looking up any specifications and posting because after hours of searching online I found nothing. Attached are photos of the spindle and I have cleaned up most of the surface rust while letting it soak in some oil overnight.
    Attached Thumbnails Attached Thumbnails BT40 spindle year dowm-image-jpg   BT40 spindle year dowm-image-jpg   BT40 spindle year dowm-image-jpg   BT40 spindle year dowm-image-jpg
