Hello
I have buy a cnc murata centrium 3000 punch machine but i need help !
I was working on my machine i set to zero and the index tool was rotate this is normal but suddenly the index tool stop when I looked i see a bolt it touching a tool causing the down index tool moving 3-4mm on the left so when i turn on the machine on the monitor showing the alarm "pins out" when i looked the pins i see the down pins its ok but the upper pins its not entering on the holes !
Please can you help me how to set the index tool on the normal position ?
