New Machine Build 6-axis Horizontal Machining Center for Education - Page 37
Page 37 of 44 FirstFirst ... 2734353637383940 ... LastLast
Results 433 to 444 of 521
Thread: 6-axis Horizontal Machining Center for Education
  1. #433
    Aug 2016
    Default Re: Redesigned Y-Axis Carriage with Rotary Table
    No, not the nut mounts. The flanges on the nuts in the red circles should be where the blue circle is.
    6-axis Horizontal Machining Center for Education-screen-shot-2018-08-09-7-21-a
    6-axis Horizontal Machining Center for Education-screen-shot-2018-08-09-12-16-a
    Attached Thumbnails Attached Thumbnails 6-axis Horizontal Machining Center for Education-screen-shot-2018-08-09-7-21-a   6-axis Horizontal Machining Center for Education-screen-shot-2018-08-09-12-16-a
  2. #434
    *Registered User* ishi's Avatar
    Jun 2018
    Quote Originally Posted by footpetaljones View Post
    I see, but how would this make tightening easier?
    Sorry, I'm really slow on that one...
  3. #435
    Aug 2016
    Default Re: 6-axis Horizontal Machining Center for Education
    It eliminate the need for a 12" extension on your ratcheting wrench and remove the motor that would be occupying the space your wrench needs to be in.
  4. #436
    Gold Member handlewanker's Avatar
    Sep 2006
    Surly that is just an Allen key job to tighten the cap head screws?.....either side the space is the same with the screw in the way...……...OK, so the nut is more to the outside (right hand side) of the bottom face and what you are saying is the cap head screws in the flange will be easier to get at from the right hand side with a ratchet wrench.....….once the screws are in finger tight you don't need a ratchet wrench to tighten them, just a longish Allen key.....but ideally then I suppose it WOULD be better the way you said......Ishi is just getting too lazy to redraw his pet subject......LOL.
    Ian.
  5. #437
    Jun 2018
    I mounted them nut facing motor because this is what NSK did in their video:
    I wonder if the orientation matters. I can't think of a reason why it would, but I would like to make sure, because it will have an impact on several components if we want to benefit from full potential travels on all three linear axes.
  6. #438
    Jun 2018
    Quote Originally Posted by handlewanker View Post
    Ian.
    Lazy week-end indeed...
  7. #439
    Jun 2018
    Default Full Horizontal Carriage
    Here is the redesigned horizontal carriage mounted on the machine's frame.
    Attached Thumbnails Attached Thumbnails 6-axis Horizontal Machining Center for Education-screen-shot-2018-08-11-3-53-a   6-axis Horizontal Machining Center for Education-screen-shot-2018-08-11-3-54-a
  8. #440
    Jun 2018
    Default Redesigned Support Mount Flange
    The flange on which the support mounts are installed on the X-axis carriage had to be redesigned in order to provide clearance for the flanges of the nut mounts.
    Attached Thumbnails Attached Thumbnails 6-axis Horizontal Machining Center for Education-screen-shot-2018-08-11-4-03-a   6-axis Horizontal Machining Center for Education-screen-shot-2018-08-11-4-03-a
  9. #441
    Gold Member
    Jun 2010
    Of course it matters which way around you mount them. They only work in one direction.
    Um .... let me think about that again ....
    Cheers
    Roger
  10. #442
    Sep 2006
    Rog....gasp...you mean it won't work in the other direction????…..Ishi will have a purple fit if he has to revise the whole of the drive trains.
    Ian.
  11. #443
    Feb 2017
    Finland
    Default Re: Full Horizontal Carriage
    Quote Originally Posted by ishi View Post
    You should round or facet all inner corners.. any sharp inner corner is easy cracking point.
  12. #444
    Jun 2018
    Quote Originally Posted by jkkmobile View Post
    I believe this is what I am doing. If you see any in need of rounding or faceting, please let me know.
