Newbie Hi I am looking to build a CNC mill/router.... - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 31 of 31
Thread: Hi I am looking to build a CNC mill/router....
  1. #25
    May 2018
    Quote Originally Posted by hanermo View Post
    The typical understanding or "feel" is for 50x less rigidity than a metalworking mill/lathe needs.
    I don't follow, why would metal working machines need so much less rigidity?
  2. #26
    Mar 2003
    Default Re: Hi I am looking to build a CNC mill/router....
    I think he means that metal working machines require 50x more rigidity than woodworking machines.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #27
    Mar 2003
    Quote Originally Posted by KainKelly View Post
    Failing that, my last resort is to look at bench top Mills that can have a full enclosure built around. Could something like that form grizzly or bolt on tools mill stainless? The RPMs are right, the look is not. They look so flimsy maybe make tame cuts, I would bet that they have been CNC converted before.
    g0704.com
  4. #28
    May 2018
    Quote Originally Posted by ger21 View Post
    Thanks that is exactly what I was looking for! I am going to go compare prices and start looking into that, I will probably build a router first. Those aluminum parts look easy enough to make on a good machine.
  5. #29
    May 2018
    Hey guys quick question, this says the y axis ball screw is 14 in long but states it only has 6 ins of y travel, it that from the center of the table forward and backwards?
    Link:
    6" x 26" Vertical Mill with Power Feed and LED Worklight | Grizzly Industrial
  6. #30
    Gold Member
    Apr 2004
    Oakland CA USA
    It's from one side of the table to the other (minus 1/16" on either side). Most of that screw's length is taken up by the journals at either end for the bearings and the attachments for the handwheel.
    Andrew Werby
    Website
  7. #31
    May 2018
    Quote Originally Posted by awerby View Post
    Okay thanks, I also saw on YouTube a mod some one did to add more Y axis by cutting the base, do you have any idea what that might have been?
