Another video of the turret making aluminum spacers!
VIDEO (this is a long winded movie, be patient)
Station #1 is a push bar, which puts the stock at the starting position.
Station #2 is a facing tool, removing .005" material.
Station #3 is a 1/2" stub drill, set for .4" depth.
Station #4 is a 5/8" shank boring bar, finishing bore to .525" ID.
Station #5 is a turning tool, set to turn .87" OD x .39" long.
Station #6 is a parting tool, set to cut of the part at .37" long.
Next operation will be to hold the new parts in a collet, and face them to the final thickness.
These little spacers are used between the ball bushings and snap rings on the x-axis slide of the Mini & Midi-Routers. Two required for each router.
Widgit
