I've got a reply to the question elsewhere, decided to post it here also, just in case anyone else is searching for the solution.
Good afternoon Mr. Andrejev
I guess the voltage of the backup batteries was cut for longer than 20-30 minutes.
In this case the machine 'forgot' the magazine position and you need to set it again.
spider solitaire
- After clearing the start point data, move the magazine position nr.1 to the tool change area and clear the start point once again.
- Finally disable the ATC maintenance mode (I/O), (1), (Enter), (page up) set 0 for (ATC maintenance mode) and power the machine off and on again.
- If everything went well you can start to work with the machine as usual.
Kind regards / Mit freundlichen Gruessen
Thorsten Schrodt
Technical Support
Nomura Trading Co., Ltd.
