Problem How would YOU turn this feature?
Results 1 to 5 of 5
Thread: How would YOU turn this feature?
    Nov 2006
    Default How would YOU turn this feature?
    I have 100 of these to do and more is likely. I would be referring to this interior cone feature. The only way I know of right now is a custom modded carbide round with a radius nose and slightly relieve the sides. However, they may just break like a pencil lead. It would be nice to have more beef in the cut but I don't know what else to do. Not looking to throw hundreds at this problem.
    I was planning to get what I could out with general tools, then plunge cut what I could with the pen, then contour it with the same tool.
    Attached Thumbnails Attached Thumbnails How would YOU turn this feature?-k1b-01-mod2-pdf
    May 2004
    Form tool.
    Jan 2010
    Those things are illegal to make without the correct BATFE license.
    Member ChrisW's Avatar
    May 2003
    Lake In The Hills
    Check micro 100 or internal tool.
    They may have this tool already made
    Jul 2016
    I would use a 55 or 35 deg od insert laying flat
    I believe sandvick has a boring bar that would get
    U want u need..
    I done something like that before...
    As far as rough and finishing countour face it..
    Go easy on depth of cuts until your confident it's
    Giving u tool life u expect.
