Need Help! No timing belt available for lathe - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: No timing belt available for lathe
  1. #21
    Sep 2008
    australia
    Thank for the pics AL
    I intend on electrically connect the spindle to the lead screw one day, one of many projects.
    Russell
    www.vapourforge.com ..................I recycle electrons.
  2. #22
    Dec 2003
    We are gradually turning it in to a Mazak
    *Registered User* Noriek's Avatar
    Nov 2018
    Default Re: No timing belt available for lathe
    Hi Russel
    I just picked up on your thread about the 6125 i am in the same problem, have sent a query to the Sidermeca site. However the motor mod with the vfd is of interest to me.
    I am about to make a 72 inch belt grinder but i need my lathe to make some parts, can you provide me with some info to mod as yours. i am in perth WA
    many thanks
    keiron
  4. #24
    Member Gasssen's Avatar
    Feb 2019
    Quote Originally Posted by rusel View Post
    Need help, suggestion, advice
    I can not locate a timing belt for my CQ6125 bench lathe (China made *$@^)
    Been to two different belt retailers and they can not identify the belt. Pitch is about 4.8mm, 18mm wide and 2.2mm thick with 118 teeth
    The place where I brought the lathe (Hare & Forbes) told me to replace the pulleys with standed pulleys as there do not stock spares #$*@&.
    First problem with this is the large timing pulley and the 3 vee pulley cone are all one part
    Any one be here before?
    Any suggestion
    Russell
    I have the same lathe. For future problems:
    Its a M1.5 - 124 - 15 belt. (M= module , Z= teeth , 15mm)
    Grizzly #: P0516944 - TIMING BELT 1.5 X 124 X 15MM
    Sieg #: C6-1544 Synchronous Belt / SIEG C6 124T Belt
  5. #25
    Feb 2019
    C4A-210 Timing Belt 1.5*124*15 also from a SIEG lathe
  6. #26
    Member mactec54's Avatar
    Jan 2005
    Al thank for the reply
    Tried a 5mm pitch belt on the pulley and it start to rides over the teeth after 2-3 teeth.
    It is less then 5mm pitch.
    Here is photo of large pulley as you see it is one part with vee pulley
    Russell
    Recut the teeth to suit a T5 Belt this is most likely the easiest way to fix it
    Mactec54
