Brian, thanks.Originally Posted by speedracer
The syntax is very simple, just the program's path/name, a space, then the file to send's path/name.
If you're always going to send from the same port, then disable "Prompt with Polling" under Options\System Settings. Doing this will launch SComm and send the file.Code:c:\program files\scomm\scomm.exe c:\ncfiles\customer\file.ncf
I programmed it in VB6, but am considering a migration to VB.net. (So far my experience with .net has resulted in much longer load times for apps that should load very quickly.)
If you're comfortable with computers, you can add SComm to the right mouse menu for explorer, so you can just select a file from there, right click and send it that way.
