PARTMAKER USERS
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: PARTMAKER USERS
    Jan 2008
    Mar 2007
    I dont use it personally, but the company I work for does. Sometimes the program is a blessing to have, and other times i am better off writing a program by hand! Oh well, it keeps things exciting! How does everyone else feel about it?
    Jan 2008
    I feel the same way you do. Most of the time I write the program long hand. When it comes to 3D machining or engraving I like it alot. The posts for our swiss machines are not exactly right and it gets aggrevating sometimes.
    Registered ghyman's Avatar
    Feb 2005
    Same here... it works OK for generating complex tool paths, but I always would end up doing most everything longhand.
    Mar 2007
    I have come to the general conclusion that the actual program Partmaker is a decent program. The area where it is lacking is in the post-processors, atleast for swiss machines. It seems like all that our programmers do is complain how everything looks great when they run a simulation, but the code which it creates usually needs manual editing to even make it run. Does anybody have any posts which they created/modified which work well on citizens or stars? I hate to see what seems to be a good program have its name tarnished because of poor posts. Thanks everyone!
    Feb 2008
    I use Partmaker every day, it is a good program, although some manual editing is generally neccesary. ut it does a good job of reducing the amount of time it takes to write complex programs.
  7. #7
    Apr 2007
    I don't use partmaker myself but we do use it in our shop. We have had to work with the company that we bought the software from to get the post figured out. We post to our nakumura with usually no problems. Our citizens on the other hand have problems. Productivity the company that does the tranining on partmaker is working on that problem for us. Good luck
  8. #8
    Nov 2003
    Partmaker was one of the biggest mistakes that our company ever made. We mainly got it for our star SV-32. I don't think that the people who wrote the program even know what the machine looks like let alone look at the books for a sample program. In the time that it takes to go through the program and generate something that won't work on the machine I can have 4 programs wrote and debugged. Word of advice STAY AWAY!!! The portion of the program for the turn mills and mills isn't much better.
    Carl
  9. #9
    Jun 2008
    Amen, brother. I've been using it for about 8 months now and don't like it one bit. The problems I have with Citizen posts isn't as bad as the Star posts, but it still requires major rewriting. I have e-mailed my post problems to Partmaker Support and after several weeks of receiving modified posts (as many as four), the problem still isn't fixed. As a matter of fact, each new post I get comes with another set of problems. Don't they ever try these posts on an actuall machine? The guys at Star have been to our shop for programming seminars and tell us to stick with programming at the machine as Partmaker is good for making pretty pictures on your PC, but not good for running a machine. Unfortunetly, us programmers don't have many choices when it comes to programming software for screw machines. I see here on these forums that Esprit has it's post issues also. I am waiting for the more repitible software companies (such as Mastercam) to finally get on board with the screw machine industry. Until then, keep your pencils sharp and your calculater handy.
  10. #10
    Dec 2007
    Does anyone use it for Hardinge? We are receiving a new turning machine with live tooling and this is the software they suggest. I will be responsible for programming it and the rest of our turning centers and mills. Is there any good experiences with the mills?
  11. #11
    May 2008
    You will have to learn to config your post for your style of programming. I have finally reconfiged all our post for our SV-32's, SR-20's, and the SB-16 to post directly to the machine's. On a second note I have reconfiged the Mori post to do the same. Just hang in there and it does pay off. There is no other software that even comes close to the power this software has for Swiss. We also have Mastercam and UG that take's alot of time to even run right in the swiss machines. Partmaker will save you so much time although longhand will always be there for backup!
  12. #12
    Nov 2003
    But the problem is you have to configure something that should have already been done. For right now I'm sticking to programming by hand, it's quicker and more reliable and readable to the next person.
    Carl
  13. #13
    Nov 2008
    Yeah, it should have been done already, but it's not. I had to just wade into the post and try to figure out how to make it work. If you spend the time and stick with it, you can make it nearly "post & go" for most types of parts. After quite a bit of fussin' & fightin', we've got posts that work real well for star SR's and SA's.
    The software is still unwieldy, but there aren't many other options. Now that we've learned how to use "Config by Click", we can accomplish almost anything we need.
    That said, we all wish the package was easier to work with.
    Ken
  14. #14
    Dec 2008
    We just bought a SR10J type C and bought the full load of PartMaker to make this our first foray into CNC easier- or so we hoped. How do I get the posts right for this machine? Any suggestions will be greatly appreciated.
  15. #15
    Nov 2008
    Default Post Processors
    When I started I had no experience editing posts. Here's how I got started; After you have gotten your process table where you want it, go to Job Optimizer, Configure Post Processor, Launch ConfigPost. Click any line you want to edit; it will take you to the post, to the code that tells it how to write that line. Just experiment until you figure it out. Study it, change something, do a "save as" so you don't lose your original post, then see how it changes. It takes a bit of time and effort, but you'll eventually figure it out and get yourself a customized post. Guard it carefully.
    Good luck and Godspeed!
  16. #16
    Dec 2008
    I use partmaker almost everyday to create about 70% of my programs. Most programs will need to be manually edited due to custom tooling we have. Threadwhirlers and such are all custom. Most profile paths and general milling/turning is programmed correctly though.
    I have come to the conclusion that for swiss machines this is as good as it will get.
  17. #17
    Dec 2008
    Default Help?
    Hi Christian,
    Have not heard from you in a while. Hope all is well.
    Drop us a line at work about the manual editing your having to do and we can see what we can do about minimizing it as much as possible. Have you got the latest Posts? That might help. Also, have you downloaded Version 9.1? Working on the Solid model is a huge help now.
    Bill Cain
    Quote Originally Posted by ChristianK View Post
  18. #18
    Dec 2008
    Default Right Posts
    Hi George,
    It was nice talking with you the other day. Thought I would just answer your question here also.
    PartMaker will fix any problem with any of our Post (Must be on Maintenance though). Its very easy to report a problem using the Help - Technical support menu. Have the Job files out and attach a Post Modification Request form with them and we will look at what needs to be done. Any questions, you can call and we will help you fill out the form or discuss with you what is happening. Please note, We change posts because the machine may not run, not because someone wants the coolant code dropped 1 line. We give out Config-By-Click and ConfigPost Lite for that purpose. This is what Ken uses to modify his post.
    Bill Cain
    www.partmaker.com
    Quote Originally Posted by GeorgePlzak View Post
  19. #19
    Dec 2008
    Hey Bill,
    Mark is having me take a "class" on postconfig so that when i'm sick and such maybe the other programmers and edit and run my programs. Right now most of our stuff is manually made due to threadwhirlers and having to move the gangs around to fit it all in without crashing. I don't really think we could configure a post to put that code out correctly ya know?
    thanks,
    christian
  20. #20
    Dec 2008
    Default Sample Code
    Hi Christian,
    I have worked with many people to get special code output. The best thing to do is send a Program along with the modified code.
    Also, I beleieve we added something to the post recently to allow for the clearance movement whe using a Thread Whirl. Give a call to Steph and ask her to send you your latest posts. I will gladly help with any edits your looking for explaining everything I do so you can begin learning how to edit the post. Bigest thing to learn is how the Flow works along with the logic thats in there.
    Have you come to our Intruduction Webinar for ConfigPost? Thats the best place to start. After that, we always do advanced classes pretty much 1 on 1.
    Bill Cain
    Hey Bill,
    thanks,
    christian
PARTMAKER USERS
PARTMAKER USERS
