You could use Task Manager to see if you get 100% CPU load when calculating now. If you have low CPU usage during the calculation, I would not expect to see much if any gain.
Will I save a lot of time in toolpath calculation if I buy a faster pc with a faster motherboard and a faster cpu?
Anyone here with experience?
CAD, CAM, Scanning, Modelling, Machining...
I have a new i5 that's way faster than my old i7.
It's going to depend on the software you're using. It might be a big difference, or it could be zero difference.
If you are comparing processors from different generations, the newer one will most likely be better.
As fast as my i5 is, I certainly wouldn't spend the money for an i9.
UCCNC 2017 Screenset
