Need Help! CNC Machine machining parts that are located in the corners of a sheet incorrectly
Results 1 to 2 of 2
Thread: CNC Machine machining parts that are located in the corners of a sheet incorrectly
    Member nategjl's Avatar
    Apr 2021
    Default CNC Machine machining parts that are located in the corners of a sheet incorrectly
    Good Day Everyone.
    My Blue Elephant ELECNC-1530ATC Machine is machining parts that are located in the corners of a sheet incorrectly. When I simulate the problematic codes on an online NC viewer and also in the software that I use, Cabinet Pro, the machining comes out perfectly, but when it gets to the machine via a thumb drive the machining on the parts close to the corners of the sheet gets thrown off randomly. It was working before but then started to give this error recently.
    See an attached example.
    Attached Thumbnails Attached Thumbnails CNC Machine machining parts that are located in the corners of a sheet incorrectly-sqjq0803-jpg   CNC Machine machining parts that are located in the corners of a sheet incorrectly-img_4796-jpg   CNC Machine machining parts that are located in the corners of a sheet incorrectly-capture-jpg   CNC Machine machining parts that are located in the corners of a sheet incorrectly-img_4859-jpg
    Member elephantcnc's Avatar
    Nov 2011
    shandong
    Default Re: CNC Machine machining parts that are located in the corners of a sheet incorrectl
    Hello, we are Blue Elephant CNC. If you have any questions, please contact us.
    Contact Information:
    https://www.elephant-cnc.com/
    Email: manager@elephant-cnc.com
    Whatsapp/mobile: +86-15064026772
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
