Hello.
Unfortunately localhost is unable to open.
It would be interesting to try your program.
Regards.
Hi guys, I'm making the converter SVG to G-code:
https://veiseliha.com/#more-demo
It uses SVG syntax described here:
https://veiseliha.com/layered-svg-tutorial
Will appreciate any help in testing it, especially if you use anything another than LinuxCNC
Hello.
Regards.
This could be a useful development.I know that Inkscape has the capability to create Gcode from an svg file but have never found a way to make it happen,if there was a contest for the least intuitive program ever I believe Inkscape would be a contender.
Oh, it's typo, try https://veiseliha.com/layered-svg-tutorial
routalot
I tried Inkscape G-code plugin but without any significant success, I rather want to have online tool, hope it will be useful not only for me.
I rather want to have online tool,Like this?
https://www.makercam.com/
UCCNC 2017 Screenset
Do you tried Inkscape with G-Code plugin ?
Telegram: @Shineworld
But the tool still needs some beta testing, I will appreciate any help.
It seems Makercam only behaves with some browsers and security settings.
The death of Flash will not be mourned.
Anyone who says "It only goes together one way" has no imagination.
Hello.
For an unknown reason I could not reply with a PM.
What I will be doing is using some of my already converted files so that it will be possible to compare the generated G codes. Then I will run them on my viewer and watch their execution. I´ll try to post the video files.
Regards.
or this?
https://www.cnczone.com/forums/uncat...-software.html
The more the merrier ?
cyclestart
They all have a fatal flaw
https://www.drdobbs.com/windows/a-br...ng-r/225701475
Created video:
Hello.
The posted files are the ones I´ll be using to test your software. This is the type of patterns that our new machine will be required to quilt.
I´m in the process to convert these files using the technique I already have. This far I have the DXF´s.
I´ve also included the original SVG´s in case you want to experiment on your own although I don´t think it is what you want.
The filename extension was changed to txt as the uploading protocol does not allow SVG files.
I will post my results as soon as possible.
Regards.
BBMNet
Answered in the private message but couldn't send file, sending here.
Splitted the sample into multi simple shapes, because complex shape will probably run into calculation timeout.
I also am looking for a SVG or DXF to gcode file converter for my quilting machine. Did you have any luck finding one?
Hi, recently most of people who tried to use the converter tried to convert plain SVG without path descriptions. It will not work because the converter doesn't know how to process the path (from outside or inside, mill cavity or just draw outline). We shoud say which operation to apply to each path we want to cut, by adding a description to the path.
In the SVG source it looks like:
<path d="m 173.7147,158.02643 77.7675,0 c 22.43224,0 40.4914,18.05917 40.4914,-40.4914 z">
<desc>fill z=-0.5...-11 dz=0.5...2...2 part-name</desc>
</path>
Possible keywords are:
"cut" - cut the shape
"fill" - mill the shape as a cavity
"outline" - like fill but just cut inner outline
"zigzag" - like fill but without inner outline
and
"blank" - the rectangle converted to path - all shapes will be placed relatively to blank
In the Inkscape editor it looks like:
The red rectangle here is a "blank" path.
Full tutorial is here:
