GSimple (Free 3 Axis CAM) Version 1.08 - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 74 of 74
Thread: GSimple (Free 3 Axis CAM) Version 1.08
  1. #61
    Feb 2007
    Greece
    Version 2.04 will be out in about a couple of weeks. The major improvement over the last version is the inch mode -it has been redisigned and the old problems (small deviations in the data) have been eliminated. Version 2.04 is currently in the debug state.
  2. #62
    Feb 2007
    Greece
    Default GSimple Version 2.04
    At last the new version is out and can be downloaded at http://www.gsimple.eu
    The installation method has been changed completely and there is also a new users manual which is (almost) complete.
  3. #63
    Aug 2009
    Hello to any g-simple users. I am looking to see if anyone has set up g-simple with a bridgeport set with sx15. I am looking for a config file or how to set up the config file for a bridgeport. Thank you in advance.
  4. #64
    Jul 2007
    When will there be another update?
    I still use 2.03 the later ones had problems in INCH mode.
  5. #65
    Dec 2008
    Colombia
    Hi Sotiris: I am learning how to use your program and I have to say it is great. Congratulations!!! Gsimple works very well creating the g-code in my pieces. I will try to cut some of them soon. I will be reporting my adventure. Thanks a lot!!!!
  6. #66
    Dec 2009
    When I go to make the g code I come up with the error of: No engraving tool present for text ID 2. I have added the tools under the Tools tab and in the setup and still come up with the same error. Is there a tutorial that expands about engraving and the setup?
  7. #67
    Feb 2010
    Can I not snap to an object to select line ends? Snap is on, all selections in snap options are turned on. I would think selecting LINE would allow a "pick" feature or something other than coordinates. Coordinates will be awful slow, error ridden drawing methods.
  8. #68
    Feb 2010
    oops.
  9. #69
    Registered TheJollyMiller's Avatar
    Dec 2013
    Preston
    I would just like to say that Gsimple is a brilliant programme and that it has helped me enormously in coming to terms with G-Code.
    I have used it to make quite complicated parts and once you have found all the wrinkles it is a very powerful tool.
    I use it to produce G-Code for my Denford Novamill that is running on Mach3.
  10. #70
    Dec 2013
    Preston
    Default Gsimple is great
    Attachment 261559
    OOPS!
    Double post. So I will give you a picture. ;-)
  11. #71
    Jul 2009
    Default Re: GSimple Version 2.04
    S.Kontogiannis,
    Where has the gsimple download been moved to? The stated URL does not download.
  12. #72
  13. #73
    Quote Originally Posted by keith20mm View Post
    S.Kontogiannis,
    Yes I was wondering thos as well I would like to use this program does anyone have a link where I could download it?
  14. #74
    Member Davidstech's Avatar
    Oct 2019
    Cool Re: GSimple Version 2.04
    Quote Originally Posted by Lee Evans View Post
    Here is the download link, I searched for the website on archive.org.
    And found the link, there a six backups of it, I used the most recent one.
    It works on Windows 10 btw.
    Let me know if this helps. =-)
    https://web.archive.org/web/20170104...e.eu/Setup.exe <--- Download link
    https://web.archive.org/web/20161127.../download.html <--- Website link
