Originally Posted by
S.Kontogiannis
You can easily engrave a complex drawing with GSimple -with some limitation.
Required steps:
1) Import the dxf file
2) Select the lines, arcs and circles you want to engrave (see below)
3) Select from the Menu Compose/Engraving. Supply the desired data (width and depth) and click OK
4) Attach appropriate tool on the toolholder
5) Make the G-code
To select multiple objects. There are three methods:
Method A)
Left click on the object (in our case line, arc or circle) with the SHIFT key pressed down. If the SHIFT key is not pressed, clicking on any object will automatically deselect all other, already selected, objects. To deselect a selected object click on it with the CTRL key pressed.
Method B)
Right click on the object. This action will open up a pop-down menu. Select "Select" from the menu.
Method C)
After selecting a line or arc with method A or B, right click on any connected line or arc and then use "Auto Select" instead of "Select". This action will select all connected elements. The auto selection will stop if there is no other connected element or if there is a crossroad (3 or more elements connected on the same spot). Method C can save you a lot of clicking (which is sometimes anyway impossible)
Limitations
1. The current version cannot handle more that 1024 drawing elements. If your dxf file containes more they will be discarded with the message "Too many drawing elements". In this case you can split up your file in two (or more) parts and compile them with gsimple separately.
2. The current version will not handle multy-pass engravings.
