free cam software for lathe
Results 1 to 4 of 4
Thread: free cam software for lathe
    Jul 2017
    South Africa
    Default free cam software for lathe
    Hello Chaps,
    76 years old and still kicking !!
    I am wanting to use a cam package to convert simple 2d (autocad) drawings
    to toolpaths for my small lathe working in mach3.
    Please suggest options.
    best regards
    fred evans
    May 2016
    Default Re: free cam software for lathe
    Hello young man
    maybe you want to give my program GrblGru a try.
    It is free and can read DXF and SVG files and generate GCode from them.
    You can find me 4 posts below in this forum.
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Welcome!
    Although not free, but certainly not expensive either check out SimplyLathe from MR-Soft Nc Software Tools
    You can download and test without a license as well as run simulations on the generated G-code and a bunch of other features but you need a cheap license to save tool paths.
    See what you think.
    Jun 2018
    Tasmania
    Quote Originally Posted by GrblGru View Post
    Hello young man
    Hi GrblGru,
    It is very worthwhile that you also post some more information about your software which I found here:
    https://discuss.inventables.com/t/gr...d-lathes/44042
    Your description of your software is very modest but personally I feel you have an absolutely marvelous/very clever piece of work there and you need some recognition.
    For example, I have been looking (for a very long time) for affordable and decent software that can reverse engineer G-code back to DXF so I can edit it using my preferred Drawing/G-code/Simulation software (SimplyCam).
    I have found very few but none like yours. It just works (creates all polylines and seems to have additional entries which are easily edited).
    So easy to use as "Import NC" and "Export DXF" - brilliant!!!
    Extremely useful for me - many, many thanks - from me, this feature alone is just magic!
    Thanks (gee I seem to be repeating myself here :-)).
