Need Help! Cimatron IT13 in Windows 10
Results 1 to 2 of 2
Thread: Cimatron IT13 in Windows 10
    Feb 2014
    Post Cimatron IT13 in Windows 10
    I installed Cimatron IT13 in Windows 10. The environment works, but the mouse does not work well on the menus, when I try to select some menu item, it jumps and does not let me select it. I tried changing mouse parameters and it did not work.///// Instalé Cimatron IT13 en Windows 10. Funciona el entorno, pero el mouse, no funciona bien sobre los menus, cuando intento seleccionar algun renglón del menú, salta y no me deja seleccionarlo. Probe cambiando parametros del mouse y no funcionó.
    Member Tulak's Avatar
    May 2004
    Chicago
    Default Re: Cimatron IT13 in Windows 10
    solidkim's Avatar
    Feb 2024
    Use Windows 10 version 1607 or 1703
    When installing Ciamtron it13, if you select compatibility XP SP2, it can be installed and run.
    Check Windows version
    On the Windows mark -> Right click -> Run -> Enter "WINVER" and enter
    solidkim's Avatar
    Feb 2024
    I had success doing this on Windows 10.
    There are no problems with everything, including mouse and screen movement.
