Found that with Google:
https://www.innovaart.com/faq-items/...k-and-pk-mean/
Hope it helps
Richard
Hi all,
I have this plotter file (.plt) that uses non-standard HPGL commands.
I don't know its origin or what program has produced it. It is a job file for a Chinese made vinyl cutter.
I really need to know what these commands are.
So, here is the file. I removed most coordinates to make it shorter. It does not have any line breaks or white space.
I need to know what the following commands mean, including their fields:Code:MK4,4,0,0;IN;PA;SP1;CB1;PU4,4;PD4,5,4,7;PU120,15;PD122,18,125,12,150,33;PU3142,0;!PG;;
And what is the significance of the double semicolon at the end?Code:MK4,4,0,0; CB1; !PG;
Thank you.
- please help : output file from Enroute have "plt" extension and not "cnc"
- Newbie- Xilog Maestro - Use CSV file besides include each "pgmx" file on "Nesting Wizard"
- Duality lathe, whats are maximum "starts" can it make threading with PATHPILOT?
- Need Help!- Xaxis starts to "jump" during routing
Hope it helps
Richard
Yes, this helped, thank you.
So, MK4,4,0,0; specifies CMYK values. I am guessing the fields are in the 0-255 range.
The !PG; command should stand for 'Page', which basically means the end of the job. Although I don't know what the deal is with the exclamation mark.
So now, if only I could figure out what CB1; means.
