I need little help
Results 1 to 2 of 2
Thread: I need little help
    Mar 2018
    Default I need little help
    I am using Corel Draw X3 and I am trying to create a DXF file to use in a CNC router and, whatever I do, it seems that it does not work. Is there someone else who can take me in the right direction? I worked on it for 3 weeks and I get ****!
    Any help would be greatly appreciated.
    Sarah M. Harrell
    Member awerby's Avatar
    Apr 2004
    Default Re: I need little help
    What doesn't work? You can't create the drawing, or you can't save it as a DXF? If it's the latter, you might need to "export" rather than save. It might also help to convert your drawing to curves before exporting. If you don't want to do that, you might try this plugin: CorelDRAW Tools - The best CorelDRAW Plug-ins that offer you cutting solutions for all your cutting systems which I believe will work for free for a while.
I need little help
I need little help
